locodude
| posted on 23/9/02 at 05:57 PM |
Engine Won't stop!
Hi All
Help.
Been to see some Barnsley lads about making a tank for their big white car today and they have a problem. The car starts on the key first time but
won't shut off on it. You have to pull the battery lead off. What could be the problem. Come on all you auto 'tricians it must be obvious, what
don't they have connected? The engine is a bog std. Sierra Cossie 2wd.
Chris PTM
john_s
| posted on 23/9/02 at 06:37 PM |
I'm not an auto 'leccy, but they've not connected the coil to a permanant 12V feed have they?
John.
John Singleton
chrisg
| posted on 23/9/02 at 06:41 PM |
Yeah, thats what I did!
Check that the lead to the coil's not wired 12v permanent.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
bob
| posted on 23/9/02 at 06:46 PM |
yeah that what it be
This white thing,what they calling it and is thare a website as its causing a lot of interest?
theconrodkid
| posted on 23/9/02 at 07:11 PM |
You shouldnt go pulling the battery lead off with the engine running as you can spike the ecu,sounds like a prob round the ignition switch area,so
whats the big white thing or is it a secret?
johnston
sounds more than the coil permently wired as a car will run off the alternator if battery is disconnected
does it run smooth still or does it get rough??
u can get a hot spot in the cylinder carbon build up or wrong spark plugs re igniting the air fuel mix
although key should switch off fuel pump as well
there was an after market gizmo for turbo'd cars that kept them runnin till the turbo cooled then switched off the engine
could this have been fitted to the donor and still attached??
Jon Ison
| posted on 23/9/02 at 08:36 PM |
chris, was you in the pitlane when mine would'nt switch off ???
remember, it was the bloody fan, yeah the fan.....turned into a gearator it did, enough to make them little spark plugs glow, never seen that
B4.......
locodude
| posted on 23/9/02 at 09:17 PM |
Hi Guys
Thanks for the input, just trying to help out some Barnsley boys. The fan aint running so it's not that, the engines cold, so it's not carbon hot
spots. I'll ring 'em tommorrow with the coil info. The big white car in question is the same one you all saw at Donnington (please all you
southerners stop calling it Donny, that's short for Doncaster up here!) that looks like a Panoz. James hicost says he's building one. There's no
website Bob, they've only just got hot and cold running water up there you know! Pics should be in next Which Kit. I was going to take some pics but
the body was off and under wraps and you all know what an MK chassis looks like, even slightly modded! They are definately going to sell kits though,
just waiting for some punters.
Chris PTM
bob
| posted on 23/9/02 at 10:43 PM |
Chris
I dont think they will have to wait long for punters,i think the car is what a lot of people have been waiting for.
None of that rice burners in the back or middle,rear wheel drive and eng in the front.
As for donington how about doni or the borderline where sheep shagging ends and the people of nottingham run around in tights
locodude
| posted on 24/9/02 at 05:32 PM |
Well said Bob, all of it!
bob
| posted on 24/9/02 at 06:48 PM |
chris
i think i'm getting the hang of it now!!
locodude
| posted on 24/9/02 at 07:02 PM |
Keep up the good work! I may be going to a Lotus/Caterham 7 meet tommorrow night to keep in practice!!
I passed the thoughts of the list on to the Lads in Barnsley and they were overwhelmed! Yes the coil has a permanent 12v but they don't know from
where. Re-wire looks imminent!
theconrodkid
| posted on 24/9/02 at 09:09 PM |
probly ignition switch
