FASTdan
posted on 26/11/12 at 01:37 PM |
X Flow Engine - 90deg Dizzy Caps?
Just a quick one - as I understand it on the crossflow you can get straight and 90deg dizzy caps. Are there also two types of distributor? And if so
is the 90deg available for both?
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Paul Turner
posted on 26/11/12 at 02:34 PM |
Three types of x-flow distributor as far as I know, Motorcraft, Lucas and Bosch. Never used a Motorcraft but you can get both the Lucas and Bosch as
top and side entry, have used both. With the Lucas one the supplier had modified it to suit the clips but on the Bosch its a strait forward fit. From
memory the side entry cap for the Bosch is off a Fiat or Peugeot of some description.
FASTdan
posted on 27/11/12 at 07:46 AM |
Thanks for the info :-)
Anyone know if a 90deg motorcraft is available?
