maccavvy
posted on 26/11/12 at 09:58 PM |
thinking of losing mechanical fuel pump
Due to a few issues with the mechanical fuel system im thinking over winter changing to electric pump.
Im running a weber dgav on a pinto in my robin hood but may soon change to bike carbs.
what would you recommend me to fit. ive seen various facet pumps some solid state and i know i need a pressure regulator
is it worth doing this for starters and would i need to change the piperwork or anything.
Is the pump best off next to tank or near engine bay to save wiring routing.
any info appreciated. also rough cost of doing this
blakep82
posted on 26/11/12 at 10:01 PM |
wait til you do the bike carb conversion, and fit the bike carbs and bike fuel pump. it'll already run the right pressure, no need for
regulators and stuff, saves doing the job twice
i went for bike carbs, with sytec regulator and facet interrupter pump, but you're much easier going for the bike pump with bike carbs
________________________
maccavvy
posted on 26/11/12 at 10:08 PM |
Its just that im having issues now and may not do the bike carbs for 6 months or more.
so trying to get ideas on what to do and what i need.
blakep82
posted on 26/11/12 at 10:17 PM |
well, there are what i got
http://www.ebay.co.uk/itm/FACET-SYTEC-ADJUSTABLE-FUEL-PRESSURE-REGULATOR-6MM-/260967885010#vi-content
http://www.ebay.co.uk/itm/facet-fuel-pump-hot-rod-autograss-custom-race-car-/300822035847?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item460a63fd87
the regulator goes down to 1.5psi, i forget what bike carbs need, its 1.5 or 3psi i think... not sure, but it goes down far enough anyway, but as to
how steady they are at keeping the right pressure, and how accurate they are, i don't know
maccavvy
posted on 26/11/12 at 10:25 PM |
Thanks dude.
what ya reckon to this ?
FACET 3.0-4.5psi Fuel Pump &' Sytec Regulator 8mm unions &' filter carb mini vw
can i fit the pump up front or better out back ?
Dusty
posted on 27/11/12 at 12:33 AM |
I have had two facet square block type pumps fail and one injection pump. I have also had the facet bullet style filter block. I carry a spare of each
these days. You will also need a pressure regulator and an electrical cut-out, either impact or oil pressure activated.
The pinto mechanical fuel pump is simple, cheap, effective and usually very reliable. It fuelled twin 40's on my pinto for 20,000 miles plus
before I went zetec injection. What fuelling issues have you had?
maccavvy
posted on 27/11/12 at 07:45 AM |
every time i go to start it the fuel has dropped out of the lines. so have to pump it on the starter.
plus i will be going for bike carbs in the future and have some time over winter.
whitestu
posted on 27/11/12 at 08:22 AM |
Buy a bike pump and see if it works with the Weber. If not you save it for when you get bike carbs.
Stu
philfingers
posted on 11/12/12 at 08:58 PM |
just fitted a ZX9R pump to my xflow engined Striker. Cost me £15 inc del for the pump and 2-3hrs to mess around making a bracket
http://www.jpsc-online.co.uk/viewtopic.php?f=4&t=936&start=10
it's not running yet, but I have fuel to the carbs now and they're not leaking. Remains to be seen if it will run ok with the pump tho
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
Mikef
posted on 12/12/12 at 05:50 PM |
Hi .
I went over to a Facet silver top pump and pressure reg, filter king. Have 45 Webers on a 2l pinto and it works very well no issues all last season
on hill climbs. cost approx £60 for the pump and same for the pressure reg , which has a removable gauge for exact setting.
