Mikef
posted on 15/12/12 at 01:45 PM |
Burton extended release bearing carrier
I have just purchased one of these and the bearing to use on my type 9 . I have changed to an AP race clutch so need the extra distance this gives
you. All is fine except that the std spring clips that hold the carrier onto the release arm don't fit. So at the moment there is no way of
securing the carrier to the 2 lugs on the release arm. I have spoken with Burttons and they were a bit vague suggesting that I would need to modify
the carrier, which is easier said than done. Has anybody else had this issue please.
Andy S
posted on 15/12/12 at 03:51 PM |
Try turbosport forum
Paul Turner
posted on 18/12/12 at 11:16 AM |
Ran with one of those for about 5 years with an AP race clutch. Worried me at first but never had a problem. I have a small spring on the clutch pedal
that puts a small amount of pre-load on the cable/bearing all the time, running like this the bearing cannot move since it is trapped between the
release arm and the clutch.
Only changed when I stopped competing on the hills and sprints and went back to a road clutch and standard Ford bearing.
Mikef
posted on 18/12/12 at 01:06 PM |
Thanks Paul, makes me fell better to hear that it was fine.
