Author: Subject: Torque settings for R1 "big ends"
Leg
posted on 20/12/12 at 11:16 AM Reply With Quote
Does anyone know what they are please?
[Edited on 20/12/12 by Leg]
motorcycle_mayhem
posted on 20/12/12 at 12:26 PM Reply With Quote
Assumption:
You're using Yamaha new bolts (as you should) and stock rods honed from finest chocolate (which you probably shouldn't), not after-market items.
Then:
For the 5VY (2004-6) I perform the following:
Careful finger tight assembly, usual checks, then tighten steadily and carefully to 20 Nm. Bolts are then further tightened by 150 degrees - gauged with a carefully marked CD with the socket drive through the middle of it.
adithorp
posted on 20/12/12 at 12:28 PM Reply With Quote
What model of R1?
5vy (04-06) are... 20Nm + 150degrees, or in old money... 14ft.lb+150degrees (notes indicate oiled threads)
http://jpsc.org.uk/forum/
Leg
posted on 20/12/12 at 01:12 PM Reply With Quote
Sorry. 5JJ. All new parts.
Thanks.
renetom
posted on 20/12/12 at 05:28 PM Reply With Quote
torq
Hi
I have a Yamaha 98 YZF R1 service manual in PDF format 14.2 mb
+ a supplementary 2000 service manual 4.64 mb.
if you want them send me utu with your email
René
