Author: Subject: Anybody used one like this ?
Valtra
posted on 8/1/13 at 02:21 PM Reply With Quote
Anybody used one of these ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370701892515&clk_rvr_id=436218251362
[Edited on 8/1/13 by Valtra]
"If it looks like it works and it feels like it works, then it works"
roadrunner
posted on 8/1/13 at 03:17 PM Reply With Quote
I would also be interested in the outcome of this, as I need to sort out a pump for a zx10r installation as I can not fit the original bike pump to my tank.
Brad.
Grimsdale
posted on 8/1/13 at 04:15 PM Reply With Quote
don't know about make / model, but have used one that looks visually identical for years with no issues.
NigeEss
posted on 8/1/13 at 05:02 PM Reply With Quote
That type of pump was pretty standard on most Vauxhalls and VW during the 80s and 90s.
AFAIK most Bosch K and L Jetronic injection used them alongside a pressure regulator.
I've on feeding my Zetec.
ali f27
posted on 8/1/13 at 05:14 PM Reply With Quote
Hi pump is like mine works spot on saw your thread on block problems i have lancia delta turbo engine doing nothing if its any help
posted on 8/1/13 at 05:21 PM Reply With Quote
Yep, I've used one like that, the trick to them working well is to make sure the tank gravity feeds fuel into the pump.
big_wasa
posted on 8/1/13 at 05:56 PM Reply With Quote
Yep, mine is blue. They are just a generic copy of the old bosch pump as found on hundereds of early injected cars
Valtra
posted on 8/1/13 at 06:01 PM Reply With Quote
Thanks one and all has anybody here bought this specific company's version of the bosch type pump . their feedback shows a huge amount of stuff they are selling with mostly positive feedback (put it this way if my ebay shop sold as well I could give up the day job)
cheers
Valtra
posted on 8/1/13 at 06:07 PM Reply With Quote
Hi
Not sure if the Delta turbo block is a good substitute , I know they are all basically the same architecture so it may well be useful so long as the engine mounts will bolt on . will U2U later if you have any photos you can send to me . cheers
coyoteboy
posted on 8/1/13 at 07:53 PM Reply With Quote
Yep, used a visually identical pump too (blue) with no problems so long as you keep the pump fed from the bottom of the tank. No problem holding pressure but it was a 600cc bike engine rather than a 3 litre turbo, so YMMV
Valtra
posted on 11/1/13 at 01:04 AM Reply With Quote
Just taken delivery from this ebay listing . Looks fine , good service and quick delivery. also sent a flyer , giving an extra 5% discount if you deal direct at www.jjcraceandrally.com and enter the voucher code EBAY5
cheers
roadrunner
posted on 11/1/13 at 10:17 AM Reply With Quote
You will have to keep us updated on how it performs.
Does it give a value, interested to know if it will run an injected zx10 with a tank top feed.
Brad.
coyoteboy
posted on 11/1/13 at 12:56 PM Reply With Quote
I've had nothing but good dealings with JJC, can recommend them.
Valtra
posted on 12/1/13 at 03:13 PM Reply With Quote
Brad.
Came without any paperwork at all, but the set-up is hardly rocket science . as to spec . I guess if the ebay listing or website does not give enough detail you could contact them . They advertise it to feed big thirsty BMW engines so I supose the flow is good enough but you may need a specific pressure so best to contact them
coyoteboy
posted on 12/1/13 at 04:40 PM Reply With Quote
As far as I'm aware pretty much every single fuel injection system under the sun (other than some old old ones and some new direct injection ones) run 3 bar. It's flow that is important, and that's roughly dependent on engine power delivery and efficiency.
roadrunner
posted on 12/1/13 at 05:27 PM Reply With Quote
Brad.
Thanks for that.
Valtra
posted on 12/1/13 at 08:40 PM Reply With Quote
I seen that it's rated at 3bar but can produce over 8, also it's recommended up to 250 bhp if your Kwak is putting out more than that it's a tad too wild for a 7 but I'd like to have a ride please
