unijacko67
posted on 9/1/13 at 08:33 PM |
Exhaust Manifold Build
Exhaust Manifold Build,
Does anyone on here have access to a mandrel pipe bender and also be able to bend and supply 48mm & 53mm OD mild steel pipe. I would like the
proper un distorted mandrel bends. As everything is getting a bit tight I realise I will have to make my own or have one made if all else fails. I
also intend to measure and achieve equal length primary etc, but realise its not going to be that easy.
I could do with bends in; 48mm OD 6 or 7 90° & 4 or 5 45°
53mm OD 2 or 3 45° & 2 or 3 22°
Can anyone help or point me in the right direction regarding supply of a few bends etc. Cheers in advance.
http://www.kittenkitcar.co.uk
posted on 9/1/13 at 09:53 PM |
How about these? Looks like you can order any degree you need.
http://www.jpexhausts.co.uk/product_listing.asp?id=37&t=Bends
unijacko67
posted on 10/1/13 at 03:20 PM |
Cheers Coozer,
I only wish I knew what degree of bends I need, it will however be trial and error, cut and splice. Looks like they should be able to help thanks.
Jacko.
