Dooey99
| posted on 11/1/13 at 10:25 PM |
Engine Mount
What do you think? one of these on both sides, reckon it will be strong Enough?
fregis
| posted on 11/1/13 at 11:01 PM |
photo size
pipe to small... 25x25?
[Edited on 11/1/13 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
Dooey99
| posted on 11/1/13 at 11:02 PM |
What the bleep made that so big lol
Dooey99
| posted on 11/1/13 at 11:30 PM |
yeah its made from 25x25x4mm steel box
Mr Whippy
| posted on 12/1/13 at 12:01 AM |
you have a lot of bending stress on the engine side of the tube and sharp corners, I'd personally put a small web in there. I've made
similar but with 3 inch 3mm wall thickness tube which is a common home made type
Dooey99
| posted on 12/1/13 at 12:08 AM |
would 33x4mm steel pipe be suitable?
Mr Whippy
| posted on 12/1/13 at 12:24 AM |
It's not that pipe is stronger but just I'd use a larger diameter, you have room on that engine plate for maybe a 2 inch tube, at about
3mm it will be as stiff as that 33mm pipe being solid bar.
These are mounts I made for the old v6, these didn't even bend in 30mph crash and the tube was not much thicker than exhaust tubing, there was a
captive nut welded to the bottom plate before I welded on the tube and the rubber mount simply hand wound on
[Edited on 12/1/13 by Mr Whippy]
907
| posted on 12/1/13 at 08:40 AM |
If you use a round rubber mount I think it looks better if the plate that bolts to it is also round.
Just my 2p
Paul G
edit to add pic
  907 os engine mount
[Edited on 12/1/13 by 907]
designer
| posted on 12/1/13 at 10:12 AM |
I would use 2in (either round or square) purely to get more weld area to take the stress.
Dooey99
| posted on 12/1/13 at 10:45 AM |
I'm going to make a plate that goes onto the rubber, in the picture it is just placed together and only 1 weld has been done as I ran out of gas
