Author: Subject: Pinto water pump pulley- loctite the bolts?
James
posted on 24/9/04 at 05:27 PM Reply With Quote
As above really. Just putting it all together (again!) and there are no spring washers or anything so wondered if they should be Loctited in place?
Thanks,
James
posted on 24/9/04 at 05:41 PM Reply With Quote
I've never used Locktite on water pump pulley bolts, Most apart from the old A series {Mini etc} don't use spring washers . If in doubt use a torque wrench set to the correct setting . Shouldn't have any problems. Rusty
