Craigorypeck
posted on 17/1/13 at 07:38 PM |
Wot afr
Is 13:1 afr a bit lean at wot?
mtechmatt
posted on 17/1/13 at 08:30 PM |
Not on an NA no, depends on engine though.
V4 Engine Management System | Online Shop |
Rolling Road Tuning | Motorsport
Preparation | Engine Packages | Throttle
Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
Craigorypeck
posted on 18/1/13 at 12:11 AM |
Yb cossy 11:1 cr running 6psi via eaton. Using bike carbs and to get it right overall would need a different profile needle tbh.. Just trying to get
the profile I have to behave.
BaileyPerformance
posted on 21/1/13 at 02:06 PM |
I would go for 12/1, ideal under low boost with that compression, any more boost 11.5/1
coyoteboy
posted on 21/1/13 at 09:35 PM |
For reference I run 11.5:1 on a 3sgte with 18psi with chargecooler.
Engine should be running 8.5:1 cr but I'm not convinced it is,
getting my comp tester checked as it reports 190 psi.
