Author: Subject: Pinto aux shaft
carlknight1982
posted on 26/1/13 at 07:43 PM Reply With Quote
Pinto aux shaft
Just removed the head from my pinto to do the head gasket but I noticed the aux pulley feels like there is a lot of "slack" or play before turning the aux shaft is this normal?
Logic will get you from a A to B
Imagination will take you everywhere.
snapper
posted on 27/1/13 at 05:09 AM Reply With Quote
Do you mean bearing slack or gear lash?
Check the bolt is tight
Check you have woodruf key
Usualy the pully to the shaft is rigid, should not be any play in the drive to the distributor either
I eat to survive
I drink to forget
carlknight1982
posted on 27/1/13 at 06:57 PM Reply With Quote
It feels like there is slack when I turn the pulley as if its not engaging for a 1/4 turn
