Dooey99
posted on 27/1/13 at 12:30 PM |
zetec steel sump
Does anyone know how think the steel used to make the the steel sump is on a black top engine? As I don't want to pull my sump off until I have
the steel to modify it
Less weight more speed, more power more speed
If in doubt, give it a clout
macc man
posted on 27/1/13 at 12:45 PM |
I would say 18swg but you may find it ok to use 16swg. Make sure you bolt it down well or it may distort badly. An old block is ideal but a thick
plate may suffice.
loggyboy
posted on 27/1/13 at 12:47 PM |
About 1mm
Heres the link to modding minem towards the end of the thread
http://www.locostbuilders.co.uk/viewthread.php?tid=149348
Mistral Motorsport
Dusty
posted on 27/1/13 at 06:04 PM |
Remember the 'gasket' is not separate but bonded to the steel. Can't buy a new one so separate the steel from the ally carefully and
use goo when you bolt up.
