James
posted on 24/9/02 at 09:12 PM |
Re-fitting Pinto Sump
Hi Folks,
Just in from garage as have a bit of a problem!
Just re-fitting the sump and looking through Heynes it says in addition to a new gasket I need to use 'sealing compound' to go around where the
gasket goes. Is this really the case? Is it really needed?
I don't have any 'sealing compound' whatever the hell that actually is but I may have some of the stuff that you can bodge make/seal gaskets with.
Will this work?
Bear in mind it's a two piece cork gasket with two rubber strips to go over the crank.
Any help very greatfully recieved,
Thanks, James
johnston
| posted on 24/9/02 at 09:16 PM |
sealing compound = instant gasket
not always needed but can stop havin to do it again
theconrodkid
| posted on 24/9/02 at 09:19 PM |
you are suposed to put sealing compound,i use some black gunge from fiat where the gasket joins the rubber seals,a bit of dollop elsewhere on the
gaskets just holds them in place
rallyslag
| posted on 25/9/02 at 02:58 AM |
aye just wack some of that instant gasket crap on it and it will give it a decent seal
Old chinese proverb: "If a man speaks in a forest, and no woman hears him, is he still wrong?"
bsilly
| posted on 25/9/02 at 07:39 PM |
i just did me sump,with new gasket just a bit o grease. on the rubbers nowt. it wont leak .
mainly digger drivin me
bob
| posted on 25/9/02 at 07:43 PM |
James
I take it you have chopped the sump a bit then since your re-fitting.
johnston
| posted on 25/9/02 at 09:03 PM |
if u do use it dont use too much as it can block oil ways if it falls off the inside
