unijacko67
posted on 13/2/13 at 09:51 PM |
s2000 jumps to life
Well I finally got the s2000 engine started up as a test to see how loud my home made exhaust is. Wires everywhere and a plastic bottle with the fuel
pump sat in and me tweaking the throttle by hand on the sender unit as its still on the standard stuff.
I'm going to tidy a few bits up like exhaust springs and radiator pipes then trim all the redundant bits of loom out.
http://youtu.be/Y3L-r0uQ1L4
[Edited on 13/2/13 by unijacko67]
http://www.kittenkitcar.co.uk
NigeEss
posted on 13/2/13 at 10:25 PM |
I'd be pleased with that too.
unijacko67
posted on 15/2/13 at 12:09 AM |
Cheers, yeah happy it’s not got immobiliser issues etc. I want this car on the road in March so lots to do.
Next job bodywork, fibreglass, prop, floor pan, loom, pedal box, rear callipers, glass/Perspex, tank, rack/column, finish exhaust, bolt in seats,
harness points. I need some mint kitten rear lights as mine are a bit tired.
Hope to have the shell in primer soon.
Don't get me wrong, I know I have no chance of being ready for March.
daniel mason
posted on 15/2/13 at 07:02 AM |
good luck!
unijacko67
posted on 3/3/13 at 08:45 PM |
Cheers Dan,
I've been stripping the loom down a bit today. It still runs ok although I have had a few head scratching moments as I’ve removed needed wires
and had to re trace my steps and re-fit, soldering as I go.
All working and as a test, I popped it into gear to simulate the car being on the road to see if it would set off any limp mode errors, but blipped
the throttle and dash went up to over 200 mph (no prop attached) with no problems so I hope wiring wise another couple of weeks and I should be there.
There has to be an easier way of doing this, but I’ve only really spent about 8hrs stripping the loom so as long as I don’t cock it up it will be
worth it. Cheers.
atomic
posted on 6/3/13 at 08:50 AM |
If you get into trouble keep an eye out on eb@y for a copy of the S2000 Electrical Troubleshooting Manual for the year(s) of your donor, or PM me an
I'll dig out my copy and scan the relevant pages.
[Edited on 6/3/13 by atomic]
Xtreme Kermit
posted on 6/3/13 at 10:27 AM |
Sweet
unijacko67
posted on 6/3/13 at 10:31 AM |
Cheers, this is what I've removed so far. I’m getting there.
unijacko67
posted on 8/3/13 at 11:33 PM |
Would it be a pain to send me the cooling fan diagram. AP2 2007, no worries if not possible, I will figure it out, but have a slight niggle.
