Author: Subject: kawasaki zzr throttle cable
Dooey99
posted on 17/3/13 at 10:08 PM Reply With Quote
does anyone know roughly how long l zzr throttle cable is? will i need to have one custom made to the right length for my car? the inlet manfiold and carbs are on o/s (drivers side)
Less weight more speed, more power more speed
If in doubt, give it a clout
matt_gsxr
posted on 17/3/13 at 11:25 PM Reply With Quote
Why not just pick up a bicycle rear brake cable, or rear derailleur (however you spell that!). Not sure of the interface on the ZZR but normally you can file down the soldered end to the appropriate shape.
Dooey99
posted on 17/3/13 at 11:40 PM Reply With Quote
That is an excellent plant I never thought of that, very good idea
How would you connect it to the throttle pedal just use a couple of little u bolt clamps?
jossey
posted on 18/3/13 at 07:56 AM Reply With Quote
Mine is a road bike brake cable.
Other end I drilled a hole in a m10 bolt which fits the throttle pedal n when tight holds the able firmly in place.
David Johnson
Lightning
posted on 18/3/13 at 09:42 AM Reply With Quote
mine is done the same, except even longer as engine is in the back.
Had a nice drive yesterday as the weather was so nice. Why is it when you are trying to get rid of an intermittent misfire it refuses to do it? rhetrorical
[Edited on 18/3/13 by Lightning]
