Author: Subject: Electric water pump
beaver34
posted on 19/3/13 at 09:09 PM Reply With Quote
Electric water pump
Wanting a small electric water pump so the cooling of my turbo setup,
Any one seem or can recommend a locost alternative to a Davis Craig item
fesycresy
posted on 19/3/13 at 09:41 PM Reply With Quote
There is a Bosch auxillary water pump fitted to VW's that are very good, I'll try and find the link or part number.
austin man
posted on 19/3/13 at 09:49 PM Reply With Quote
I believe some Volvos also used an electrical pump
mark chandler
posted on 19/3/13 at 10:05 PM Reply With Quote
Like this
1999 Jaguar S-Type 4.0 V8 Auxiliary Water Heater Pump XW4H-18D473-BA | eBay
motorcycle_mayhem
posted on 20/3/13 at 09:11 AM Reply With Quote
What you need is a boat central heating pump.
I kid you not! These cool my engines and ancillaries beautifully.
Simply visit your local chandlers, or plenty on the web.
mcerd1
posted on 20/3/13 at 10:35 AM Reply With Quote
is that the same one that merlin sell ?
Slimy38
posted on 20/3/13 at 11:09 AM Reply With Quote
fesycresy, are you referring to the small electrical pump that keeps the water moving when the engine is off? I didn't think it was powerful enough to use as a standalone pump?
This is what is on the side of my engine;
VW VOKSWAGEN AUDI SEAT SKODA Secondary Water Pump 1J0 965 561 A - 1J0965561A | eBay
PSpirine
posted on 20/3/13 at 02:54 PM Reply With Quote
The VAG pumps can't be used for cooling an engine on their own.
They only circulate enough coolant to cool the engine and turbo after the engine is turned off (if that's what you intend on using it for, it's ideal).
beaver34
posted on 20/3/13 at 06:58 PM Reply With Quote
Yes that's what I'm wanting,
Next how can I keep it running after the engine is killed? Can you get timer relays or something like that?
Westy1994
posted on 20/3/13 at 07:21 PM Reply With Quote
You will need a controller, a mate of makes a programmable ones ( runs till a preset cooldown temp has been reached) but a cheap option would be a timer kit from Maplins or similar
beaver34
posted on 20/3/13 at 07:39 PM Reply With Quote
Did you say your mate makes them? If so what kind of money
Will look at maplins but not great with electrics to be fair
Westy1994
posted on 20/3/13 at 07:51 PM Reply With Quote
I don't know because I get his things free as I do the R & D testing for him, I will ask for you. It programs via a lappie or pc and only works when it needs to, i'e wont run till a temp is reached or turn off when a temp is reached. Had it on test for the last 18 months now, its running my main coolant pump and the fan, but maplins would be cheaper they do a timer which I have used before on the car for £7.99, if you arent too good at making stuff and you want one, I will build it for you for a few quid?.
beaver34
posted on 20/3/13 at 07:57 PM Reply With Quote
if you ask him that would be good
going to have a look around on the net too see if i can sort something
