pintoman
posted on 30/9/04 at 06:15 PM |
exhaust flanges
anybody know where i can get a set of stainless steel exhaust flanges from
cheers pm
TL
posted on 1/10/04 at 11:54 AM |
lolocost do a diy manifold kit for the pinto. probably not ss though, but maybe worth a look.
Terry
Rob Allison
posted on 2/10/04 at 02:53 AM |
I get mild steel one's cut by a profile cutting company. You should be able to give a template to someone near you and get them cut. Its easier
if you have a CAD drawing for them though and its not cheap if your doing 1'offs though.
Rob
type 907
posted on 2/10/04 at 04:31 PM |
I assume that if you want flanges, that you are making a manifold.
Why not make the flanges? Hacksaw/multidrill to a rough
shape and finish off with grinder & file.
Paul G
Too much is just enough
posted on 2/10/04 at 06:56 PM |
Is it for a pinto?
I assume it is from the name. Use a gasket as a pattern or ask a profile cutter to make a flange to fit it.
pintoman
posted on 4/10/04 at 07:31 PM |
i've got a set being made by
some one on the forum timf
he said its a chance to play with his milling machine
Micael
posted on 5/10/04 at 07:45 AM |
I made my own with a hacksaw and a holesaw.
piccies here
[Edited on 5/10/04 by Micael]
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
rocket
posted on 11/10/04 at 09:56 PM |
stainless flanges
www.shinybitz.co.uk
10mm thick ( st/st)
OR ring Roger on 07720713885
