| posted on 2/4/13 at 09:49 PM |
Which bike carbs do I need..
Hi guys
I have a 1300 xflow standed apart from a slight over bore. Not sure which to get for best results I've seen some cbf600 ones on eBay and some
yzf600 would any of these be any good??
I need a manifold too any recommendations where to get one from I'm in pontefract West Yorkshire.
Cheers steve
| posted on 2/4/13 at 10:41 PM |
Bogg Brothers over in Malton. Call them, Dave will tell you without any obligation.
And, if you fancy they can make the manifold and do the set up on there rolling road. Highly recommended.
http://www.boggbros.co.uk/contact.html
maccavvy
| posted on 3/4/13 at 06:34 AM |
dont forget fast dan at danst engineering...cheaper than bogg bros.
mines going to torque tune near Newark for setting up once fitted
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
puma931
| posted on 3/4/13 at 02:31 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=174513
Take a look at the last two posts in the above link.
| posted on 3/4/13 at 07:44 PM |
Puma 931 they look sweet how's it running on them?
Just u2u'd fast dan
whitestu
| posted on 3/4/13 at 08:49 PM |
If you want to do it locost style have a look at just using the original bike carb rubbers with the carbs re-spaced. All you need over and above a bit
of basic fabrication is someone with a lathe to turn the fuel feeds for you.
[img]
  manifold
[/img]
[img]
[/img]
Stu
samjc
| posted on 3/4/13 at 09:49 PM |
Steve have a chat with martin keenan down at mk engineering he can fabricate most things at sensible prices, I have some cbf600 carbs laying about if
you cant find anything at sensible prices,
puma931
| posted on 3/4/13 at 10:02 PM |
They are a really tight fit on the 1.3 against the side exit dizzy cap, but the car starts 1st time and runs well (probably needs setting up on a RR
though). I bought a ZZR600 fuel pump, classic mini choke cable and bolted it all togther, so quite easy to fit.
Just u2u'd fast dan
[Edited on 3/4/13 by puma931]
