Chippy
| posted on 2/10/04 at 10:07 PM |
Type 9
Anybody got an idea where I can obtain a gearbox mounting rubber, either 2.8, or 2.9. I have tried the ford dealers round here, and get told that they
don't stock them any more, and can't, (or won't), get them.
Mark Allanson
| posted on 2/10/04 at 10:28 PM |
The standard ford one is more sloppy than a sloppy thing. It has enough movement to put your gearbox in another county!
I bought a new westfield one for the princely sum of £8.50 direct from westfield.
The mounting bracket is home made
Chippy
| posted on 3/10/04 at 09:47 PM |
Mark
Many thanks for the info. will get in touch with Westfields on monday. ATB Chippy.
givemethebighammer
| posted on 3/10/04 at 10:15 PM |
I've just done the same as Mark. It may be useful to know that you can mount the westfield mount on at 3mm thick steel plate attached to the
bottom of the chassis rails and it keeps the gearbox at the same height as the sierra one which is mounted on top of the chassis rails. If you place
the two mounts side by side it doesn't seem as if this is true, however the sierra one compresses quite a bit when the full weight of the gearbox
rests on it. The Westfield one is virtually solid.
macspeedy
| posted on 3/10/04 at 10:27 PM |
recommended the mount from westfield a while ago no problems with it so far.
Micael
| posted on 5/10/04 at 08:09 AM |
Does anyone has mesurement of the Westfield mount?
I need to fit it between the chassie rails and slightly off center.
pic
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
James
| posted on 5/10/04 at 08:48 AM |
Nice shoe!
Is it an MK supplied feature or an aftermarket job?
James
Micael
| posted on 5/10/04 at 12:20 PM |
I knew you guys would comment the shoe!
Actually, it is a Swedish reference shoe for building pedalboxes
Micael Moose Åman
2009
Mark Allanson
| posted on 5/10/04 at 06:31 PM |
pic
I didn't measure it before I fitted it, but it does fit nicely although off centre due to the transmission tunnel being asymetrical
