imagineer
posted on 18/4/13 at 04:01 PM |
Ford Sierra Diff Codes - What diff do I have?
Before you point me in the direction of the list of codes at the top of the Engine & Transmission section, my codes don't seem to match any
of them ... ?
It's a 7.5" - lobro flanges and I'm fairly sure it's a 3.92.
Code written on the crown wheel: 9F 1281 3.92
Code stamped on the crown wheel: 88 GG-4210 AA 3.92
Code cast into the casing: 85 GG 4025 CB
Code cast on the rear cover: 85-GG-4033-BA
Is it LSD or non-LSD?
(Pictures uploaded to my Photo Archive.)
snapper
posted on 18/4/13 at 06:13 PM |
AA = LSD
3.92 = ratio
I eat to survive
I drink to forget
imagineer
posted on 18/4/13 at 07:05 PM |
Take a look at the photograph (in my photo archive), is that a helical gear limited-slip differential?
Oddified
posted on 18/4/13 at 07:13 PM |
That's an open gear diff, not an lsd. The cwp ratio is 3.92.
Ian
snapper
posted on 19/4/13 at 04:43 AM |
LSD on the left
Note slightly raised section compared with non LSD and webs go to the edge
[Edited on 19/4/13 by snapper]
I eat to survive
I drink to forget
Minicooper
posted on 19/4/13 at 10:24 AM |
Looks like a lsd to me
imagineer
posted on 19/4/13 at 10:30 AM |
Thanks snapper.
So it looks like I've got an LSD crown wheel, but open diff gears?
Minicooper
posted on 19/4/13 at 10:43 AM |
No my LSD is like that, the vicous lsd diff looks like an open diff, they have the lsd bit in the raised section
imagineer
posted on 19/4/13 at 11:22 AM |
How do I test the diff to be sure?
Rotating the input flange/shaft: both output flanges/shafts turn in the same direction.
Stop one output from turning: the other continues to turn.
Rotating one output shaft: the other turns in the opposite direciton.
What does this tell me?
Minicooper
posted on 19/4/13 at 06:05 PM |
My viscous diff, grab one output shaft hold it stationary, try turning the other output shaft doesn't matter which way, if it's an open
diff it will turn easily, if it's a lsd it will be tight to move, how tight will depend on how fresh or otherwise the lsd is.
If it's really old and worn out lsd it could still turn fairly easily and be confused with an open diff
My test was done with the input flange being free to move
A better picture of the otherside of the diff, ie not the planet gears may help in identifying what you have, from what I can see it certainly looks
like the casting of the lsd housing
CellZapper
posted on 28/7/13 at 12:36 PM |
Do Ford part numbers LIE, Looks like they fib.
Hi
I am resurrecting a 10 year old Sierra axel bought to put rear discs on a Hood 10 years ago and left in the garden to rot.
The writing on the axel beam says its from a Sierra 2.? the date can only be when it was removed.
Solid discs, Lobro shafts, 7.5" differential case.
The metal tag label has ... 89GG AA 3.91 4A 0M01
that I decoded to ... 89GG = 7.5" case AA = LSD ratio 3.91 4A manufacturing plant ??
Date code 1990 December 1st
From the super7thheaven website info I can tell that this diff is from "3.91 ratio Sierra[DL20](Aug90-) and LSD" probably.
I needed to open the diff as the input shaft was "stuck", and to see how much rust there was inside as I knew water could have gotten in
thro' the breather pipe.
The Crown wheel was very rusty at the bottom where the water was sitting....but that's another problem.
(The worst has cleaned of and the diff is free, need to see how clean I can get to make usable)
The INK numbers on the crown gear OL 7792 3.91 090
The numbers stamped on the crown gear 89GG 4210 AA 3.91
SO FAR SO GOOD
My problem the diff does not look like an LSD, it looks like the diff on the right in Snappers post above,
there is no obvious place for the viscous LSD to fit in. (backed up by the drawings in the Haynes manual Sierra V6)
SO ARE THE FORD PART NUMBERS WRONG,
or is there another explanation for the wrong numbers.
AA = LSD everywhere I look.
Anyone seen this before
How many people think they have an LSD but have one of these ???
[Edited on 28/7/13 by CellZapper]
jacko
posted on 28/7/13 at 01:36 PM |
Some one swapped the alloy tag ?
Put some photos up
Jacko
CellZapper
posted on 28/7/13 at 02:46 PM |
Hi Jacko
I think the tag looks ok, matches the crown gear,
and when I bought it I was just looking for disk brakes, there was no need to con me at the time.
I can't remember how or when I got it, but I think we took it of a Sierra in a cow shed, where the seller kept scrap cars.
(and it was cheap, like me, I wouldn't have paid a premium (cossie price) for it)
I will charge a camera and take some photo's (old fogy without camera phone)
Chris
  crown gear part number
  left view
  right view
[Edited on 29/7/13 by CellZapper]
CellZapper
posted on 29/7/13 at 10:44 AM |
maybe I should have made a new reply for the photo's
Minicooper
posted on 29/7/13 at 11:21 AM |
Open differential by the looks of it
mcerd1
posted on 29/7/13 at 12:19 PM |
^^ forget part numbers - I don't know why anybody trusts them
ford made lots of tiny changes to the diffs/axles over the years - most of which have little or no impact on what we are going to use them for, but
every version had a differenct number, even ones just made in other factory seem to have different numbers.... and then they could have easily been
swapped about / re-built at some point in there life
The only way to know what you've got is check it over yourself and it should fit one of the following:
a) 7" or 7.5" crownwheel ? (can be spotted by the style of the diff case - 7" have 2 long through bolts, 7.5" have 4 short
bolts in there place)
b) To suit push-in or bolt-on shafts (should be obvious enough , LSD's can't use the push-in shafts)
c) Ratio - 7" will be: 3.92, 3.62, 3.38 or 3.14
7.5" will be: 3.91, 3.64 or 3.36 (also 4.09 and 4.27 from the 8v or 16v scorpios)
d) LSD or not ? (as above with the back off you'll see the 'bulge' inside the crownwheel if it is one - but still best to check it
works )
to check the ford LSD off the car:
jam the input flange and try and turn one of the output flanges - if it turns fairly easily (there will be a small resistance and the other output
flange will turn the opposite direction) then its either an open diff or its a dead LSD
but if its really stiff/hard to turn then it'll be a working LSD
or don't jam the input shaft and turn one of the output ones, if its a working LSD both output flanges will turn the same way and spin the input
flange, else the input wou'nt move much and the other output will turn in the opposite direction
there are a few odd ones (like the 6.5" diff out of some euro 1.3 I think)
all you can be sure of with the car models is:
*all the 4x4's have LSD's
V6's have 3.62 / 3.64, 2.0 one have 3.92 / 3.91
*all the sierra cossie's have LSD's (2wd one have bigger flanges/shafts)
all 3.64 or 3.62
*the granny 24v cossie's had LSD's untill they started fitting traction control on later models (all 7.5" 3.64)
but someone could have swapped these at some point in there life
[Edited on 29/7/2013 by mcerd1]
CellZapper
posted on 29/7/13 at 12:49 PM |
Thanks for the advice
Hi
I know its not an LSD Diff, not that bothered, LSD and Hood 2b is an oxymoron I think. (I admit I am a bit disappointed )
My concern was the way the Tag and the crown gear agreed AA code and ratio, yet the diff is a non-LSD.
I can't believe that someone would go to the trouble of partially replacing the insides, must have been built like this.
I think the rust damage will shorten the life of this particular diff, if I decide to go with disks on the rear axle and use it.
My problem I should have stored it properly, at least I should have blocked the breather pipe properly.
Thanks for the info and guidance.
Chris
mcerd1
posted on 29/7/13 at 01:55 PM |
I don't belive that all codes with more than one 'A' in them are LSD's or ever were, I've seen too many that
weren't
