leon51274
| posted on 19/4/13 at 11:11 AM |
Starter motor woes
Hi chaps
Recently i found that my starter motor (powerlite unit) had smashed its pinion gear in to 3 pcs! Unfortunately I didn't build the car so there
we were a little unsure as to the flywheel used. Anyway to ensure I was getting the correct replacement starter I thought it would be best to count
the amount of teeth on the flywheel. This turned out to 110 teeth. Unfortunately though while counting i found a tooth on the flywheel that had
completely sheared off! So at the moment I'm thinking the starter/flywheel combinations was incorrect. Would anyone know what flywheel would of
had 110 teeth?
To add, the starter had a 10 tooth pinion.
Pic of flywheel
Many thanks
Leon
[Edited on 19/4/13 by leon51274]
AndyW
| posted on 19/4/13 at 11:13 AM |
Without knowing what engine it is, might be a bit difficult to answer!!
leon51274
| posted on 19/4/13 at 11:22 AM |
Quite right as well!
2.0 silver top zetec mated to a type 9.
I'm just in the process of uploading a pic of the offending item so I'll have that up in the next few mins.
