novicebuilder
posted on 20/4/13 at 10:11 PM |
advice on sierra differential..please
I am building a Haynes roadster. I have just removed the differential from my 1992 Sierra donor car (2.0 ltr DOHC with MT 75 gearbox with all its
challenges) and the differential is wider than the one shown in the book (donor car had rear disc brakes). I have adjusted the support brackets and
got it fitted. However whilst the differential is centrally fitted, the centre line for the propshaft is 7mm off the centre line. Does this matter?
I know the prop shaft will have joints to allow for change in angle of the drive shaft. should I make sure the prop shaft end of the differential is
exactly central or is 7mm off centre line acceptable. Grateful for expert guidance, please.
loggyboy
posted on 20/4/13 at 10:17 PM |
I believe its better if there is a slight angle as it allows the joints to move.
Either way 7mm is absolutely fine.
Mistral Motorsport
snapper
posted on 21/4/13 at 07:00 AM |
Drive shafts are of different lengths so whilst the input may not be central the out puts should also be offset
Do a dummy fit of the shafts, uprights and wishbones
Sounds like you have a 7 1/2" diff which I thought only the Cosworth and Granada used, that said Fords were not averse to using what ever they
had left in the parts bins when they came to the end of a model run
I eat to survive
I drink to forget
neilp1
posted on 21/4/13 at 10:25 AM |
On my 1990 sierra it was a 7 1/2" diff.
plentywahalla
posted on 21/4/13 at 01:11 PM |
Not necessarily.
I have mounted my diff centrally and used two left hand (shorter) Sierra half shafts. This is partly to reduce the track from the Sierra original, and
also to facilitate my inboard disc DeDion design.
I got exchange shafts with cv's. I ordered them separately and they never noticed that the second time the returned shaft was a different
length!
I should add that the diff is central about the output flanges, which is not the same as being central about the mountings. As said, it is beneficial
to have a slight offset in the propshaft flanges as it makes the needle bearings work and reduces wear. The flanges must still be parallel or you will
get vibration.
[Edited on 21/4/13 by plentywahalla]
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
