Author: Subject: misfire issue
beaver34
posted on 21/4/13 at 01:57 PM Reply With Quote
misfire issue
hi all,
i have a misfire issue on my engine, car has just been mapped with no issues afr are good.
went out yesterday dropped onto 3 i nipped back home changed the plugs over and it cleared it.
back out fine for 15miles then dropped onto 3 again
its fouling no.4 cylinder ever time,
what do i need to be looking into further? all leads sparking fine
its a 1.6 for sigma engine that ive turbo charged running ngk bcr8es plugs
thanks
posted on 21/4/13 at 02:05 PM Reply With Quote
Any differences in the appearance of the plugs ?
beaver34
posted on 21/4/13 at 02:25 PM Reply With Quote
yes the misfire plug is black and fuel covered,
if an injector fails does it operate at full power al shutdown and supply no fuel?
dave_424
posted on 21/4/13 at 02:37 PM Reply With Quote
It can do either, but the more common is it to stick wide open. Check your fuel pressure as soon as the ignition is switched off, if fuel pressure drops like a rock and you have a check valve in the fuel system then an injector is sticking open.
Also get a multimeter on the injector terminals and see what ohms it reads.
beaver34
posted on 21/4/13 at 03:55 PM Reply With Quote
Don't have anyway of checking fuel pressure at moment
Am I looked to check the ohms on each plug when engine is running presume them should be the same
perksy
posted on 21/4/13 at 05:38 PM Reply With Quote
Disconnect the electrical plugs from the injectors
Compare the resistance values on the injectors that are ok to the one that your having trouble with.
You don't need the the ignition on or the engine running to do this as you are only measuring the resistance of the individual injectors. (probe the injector terminals, NOT the connectors)
*If* the resistance values are ok for the injectors then noid lights plugged into the injector connector/s from the ECU will help show if its an injector firing issue caused by the connector/s or wiring from the ECU or even possibly the ECU itself.
beaver34
posted on 21/4/13 at 06:32 PM Reply With Quote
thanks,
just tested and the cylinder with the flooding resistance is not stable its bouncing all over the place from high to low high to low the other 3 stay stable
going to try another tester on there as the end of that is broken and its hard to make sure it not my hand shaking effecting the connection
beaver34
posted on 21/4/13 at 07:39 PM Reply With Quote
Tested again there all the same resistance
Is it worth buying a noid light kit?
Paul Turner
posted on 22/4/13 at 10:30 AM Reply With Quote
Why not swap a couple of the injectors over. If the problem moves with the injector it proves its a faulty injector.
beaver34
posted on 11/5/13 at 05:15 PM Reply With Quote
still need some thoughts regarding this
swapped out injectors, its not fuel its oil ive further found out
compression test hot and cold all good
stripped engine today so i could see inlet and exhaust valves
its exhaust valve related
here is no.3 and no.4
if compression is good, what can further be at fault valve stem seals?
thanks
posted on 11/5/13 at 05:42 PM Reply With Quote
Compressions can be good with valves that don't fully seat, the best way to check is a cylinder leakage check. I once had an escort that failed MOT due to high HC , compressions had been checked several times but a leakdown test showed an exhaust valve fault
beaver34
posted on 11/5/13 at 06:35 PM Reply With Quote
Ok will look into that,
Although its a new engine build everthing rods pistons valves etc....
