J222jra
posted on 8/5/13 at 05:48 PM |
Zx6r carbs help
Hi guys...me again.
My Danst zx6r to xflow conversion has arrived but I have questions lol.
There's seems several pipes and I have no idea what they do....if anyone can explain I would really appreciate it.
http://i1344.photobucket.com/albums/p651/J222jra/image_zps838ec807.jpg
http://i1344.photobucket.com/albums/p651/J222jra/image_zpsf8c9e9b4.jpg
http://i1344.photobucket.com/albums/p651/J222jra/image_zps4facd0dc.jpg
Also in this picture....is this the choke mechanism?
http://i1344.photobucket.com/albums/p651/J222jra/image_zps97f62192.jpg
Really would appreciate any help guys.
James
jimmyd
posted on 8/5/13 at 06:45 PM |
I believe pictures in photo bucket to be,
pic1 to be fuel in,
Pic 2 to be water heater,
pic 3 coke
Pic 4 fuel overflow.
J
whitestu
posted on 8/5/13 at 06:59 PM |
Yes, picture 4 is the choke.
The only pipe you need to use is the fuel inlet in picture 1. The rest can be binned.
Stu
J222jra
posted on 8/5/13 at 07:13 PM |
Thank you for the replies guys!!
It all seems to make sense now.
puma931
posted on 8/5/13 at 08:22 PM |
I have the same carbs on my xflow. I used a classic mini choke cable plus a reduced sized bicycle cable end to fit into the carb choke mechanism.
puma931
posted on 8/5/13 at 08:39 PM |
Forgot to say, block the water hose on the manifold, and connect the 4 vacuumed hoses together and then to the vac on the dizzy. I had to file some of
the holes on the manifold to get it to fit and you might need to port the manifold to your head. Only fit the air filter once it is running, as my
carbs pissed out fuel the first time I started it which damanged some of the foam. Take a look at my photos for further details and links to
threads.
[Edited on 9/5/13 by puma931]
J222jra
posted on 8/5/13 at 09:30 PM |
Thanks for the details Puma. Is the water connection not needed on the intake manifold then?
I'm running a H&H dizzy so don't have a vacuum connection on it.
puma931
posted on 9/5/13 at 08:08 AM |
I blanked my water connector, but you could also pumb it into the rest of the cooling system. I need mine setting up on a rolling road as it splutters
when you throttle it.
How much was the H&H dizzy? I heard they build the dizzy for the engine size and spec??
J222jra
posted on 9/5/13 at 09:34 AM |
Yes mate so I hear they are build with the engine spec in mind. Not sure of cost as it came with an engine I bought off the forum.
Think I'm going to blank the water hole in the inlet manifold.....seems a little pointless keeping it, will keep the engine bay less cluttered
as well.
How did you make your throttle and choke cables?
dave_424
posted on 9/5/13 at 09:39 AM |
Choke cable form a mini choke cable, needs to be a rigid push/pull cable.
People usually make a throttle cable from bicycle brake cables, but on ebay there are universal throttle cables in various lengths.
puma931
posted on 9/5/13 at 10:05 AM |
Throttle cable was from the same bike as the carbs and I also bought a classic mini choke cable.
as well.
FASTdan
posted on 9/5/13 at 11:51 AM |
carbs pissed out fuel the first time I started it which dramatic some of the foam. Take a look at my photos for further details and links to threads.
I have since revised the plate profile so all future plates/manifolds should locate without issue - however if anyone finds otherwise please let me
know.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
puma931
posted on 9/5/13 at 12:18 PM |
Hi Dan, Any idea why the engine will splutter/die when you apply some throttle? Starts fine with some choke, but does not idle very well (has new
leads, plugs etc that are connected correctly)?
Mathew
know.
FASTdan
posted on 9/5/13 at 07:39 PM |
Refresh my memory - what carbs etc? Are they still on the standard jetting?
puma931
posted on 9/5/13 at 08:13 PM |
LC race car fitted with 1.3Xflow and ZZR600 carbs with standard jets.
FASTdan
posted on 10/5/13 at 09:44 AM |
have you played about with the idle mix screws to address the idle issue?
Spluttering and dying on revving is likely a jetting issue - I cant recall what the standard jet size is in the ZZR's but it is likely to be
small.
maccmike
posted on 10/5/13 at 09:55 AM |
Check the pilot screws under each carb behind the float bowls, I suspect its running v rich.
turn them clockwise until gently seated, then back out 2 turns.
Start engine, turn idle p to about 1500 revs.
Adjust pilots 1/4 turn at a time waiting for engine to respond.
You want the fastest idle without hesitation - if the pilots stop effecting idle you've gone too far.
If the pilots make no difference to revs at all, the idle jets are blocked or wrong size.
[Edited on 10/5/13 by maccmike]
maccmike
posted on 10/5/13 at 09:58 AM |
also, kwaki carbs are very sensitive to airbox's.
davidimurray
posted on 10/5/13 at 10:34 AM |
Sounds like the problems I had with blocked idle jets. See my previous post here :-
http://www.locostbuilders.co.uk/viewthread.php?tid=179282
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
