johnemms
| posted on 10/5/13 at 08:00 AM |
Type 9 Gearbox Mount
I used the donor gearbox mount..
My gearstick bounces up and down over small bumps.
Obviously the mount is very soft :p
Has anyone 'done away' with the rubber mount?
I was thinking of welding a plate under the mount
to stop the travel but keep the rubber
only for vibration & isolation
cheers guys
[Edited on 10/5/13 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
big-vee-twin
| posted on 10/5/13 at 08:23 AM |
I actually made my own from 4mm flat bar and used rubbers from a TVR between bracket and chassis.
Quite solid and does have a little give for dampening.
http://www.triangleltd.com
johnemms
| posted on 10/5/13 at 08:26 AM |
Looks like I'm off under the car to sort this out ..
mcerd1
| posted on 10/5/13 at 08:48 AM |
you want the older 4 speed style mount (escort, Cortina etc...) its nice and solid
its also the one that both caterham and westfield use - and caterham actually sell it quite cheap
http://www.caterhamparts.co.uk/product.php?id_product=85
  4spd type mount :)
bigger pics:
http://i5.photobucket.com/albums/y170/mcerd1/Dax/DSCF1493.jpg
http://i5.photobucket.com/albums/y170/mcerd1/Dax/DSCF1492.jpg
[Edited on 10/5/2013 by mcerd1]
owelly
| posted on 10/5/13 at 08:52 AM |
I made my own out of polybush suspension bushes but I also mounted the engine with the same. Is it deffo the gearbox mount that is the problem and not
the whole engine/ gearbox assembly?
http://www.ppcmag.co.uk
DavidW
| posted on 10/5/13 at 10:39 AM |
I used the above part from Caterham.
It's smaller than the sierra item so I had to make an easy plate/frame to sit it in but it does the job well.
Bluemoon
| posted on 10/5/13 at 11:11 AM |
  4spd type mount :)
bigger pics:
ditto... Also never quite sure but I think the bell shaped washer thingy on the sierra mount stops excessive movement with the standard mount (I have
fitted this on mine)...
johnemms
| posted on 10/5/13 at 12:55 PM |
Done iT !!!
Added a strip of 3mm steel and rubber ..
Still has the isolation of rubber but movement almost nil ..
Took it for a spin - Fabulous
No more boingy boingy gear stick!! Yeahh
