Author: Subject: can someone recommend a decent engine oil please
daniel mason
posted on 19/5/13 at 12:16 PM Reply With Quote
im going to swap out the engine oil this week before my trackday next weekend. can anyone recommend a decent oil for the 919 fireblade and a rough ammount? i assume a 5 litre tub will be enough but im running an oil cooler up front. cheers
designer
posted on 19/5/13 at 03:17 PM Reply With Quote
Maybe a Honda bike forum would be a better place to ask the question. You will find more bike engine knowledge there.
daniel mason
posted on 19/5/13 at 03:22 PM Reply With Quote
maybe, but there are many more on here using fireblade engines in cars.wiyh info and knowledge i trust! cheers
bigfoot4616
posted on 19/5/13 at 03:35 PM Reply With Quote
i used silkolene super4 10w40 semi in my old 919 and did lots of trackdays with no issues.
now using a ester synthetic in the R1 engine but that does run a lot hotter with hard track use than the blade ever did.
also bike oil only comes in 4L tubs, may not be enough depending on oil cooler size. get 2 tubs anyway then you have some to top up with, they can use a little on track. i found i had to usually add a bit at lunch times.
sdh2903
posted on 19/5/13 at 04:09 PM Reply With Quote
I use Castrol semi synth from Halfords as I have a trade card. Whichever you get Just make sure it doesn't have friction modifiers in as it will cause slip.
This is the one I use:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263283_langId_-1_categoryId_165507
daniel mason
posted on 19/5/13 at 04:32 PM Reply With Quote
thanks guys. got the sikolene,cheers
