Author: Subject: Zetec help needed!
Sambeasley
posted on 23/5/13 at 07:27 AM Reply With Quote
Zetec help needed!
I'm running a zetec on a four brand manifold using an32/36 webber carb. I've got a mega jolt ecu and was wondering if anyone would know what would be the best map to run it on? I currently have it uploaded with the standard zetec map.
Also where would I be able to find an LSD for a zetec at a reasonable price?
Thanks!
Sam
big_wasa
posted on 23/5/13 at 07:46 AM Reply With Quote
Best map would be to have it done on a dyno for your setup.
Lsd will depend on what axle / transaxle you are using. Then there are lots of choices depending on budget,
Re your other post yep st170 manifolds are 4-2-1 with large dia equal length primary's. they are made from steel so will be easier to chop about.
Sambeasley
posted on 23/5/13 at 08:42 AM Reply With Quote
It's a zetec in a mondeo so standard subframe and axles
big_wasa
posted on 24/5/13 at 10:12 AM Reply With Quote
So the box is an Mtx75. I don't know of a cheap source of one of them. The st manifold may need some work to get it through the sump.
scutter
posted on 24/5/13 at 11:31 AM Reply With Quote
I've a ST170 box going free, 6 speed, not 100% sure about a LSD tho.
You'd have collect it from OX18 and I'm away again until the 4th of next month.
Regards Dan.
Sambeasley
posted on 24/5/13 at 11:49 AM Reply With Quote
I've got an st170 box here but I'm the same not sure if it has an LSD. Will it's bolt straight onto a zetec?
