Author: Subject: Header Tank / Expansion Tank - Which is Best?
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 2/6/13 at 05:55 PM Reply With Quote
I'm after a new expansion tank for the R1 powered Indy.
The highest point of the water system is about 3" from the underside of the bonnet.
There isn't an over amount of room at this height where I want to mount it.
What's going to be the best sensibly priced expansion tank ?
There's an "MK Indy" one on the bay ATM but its £25! I was thinking a little more Locost than that.
Anyone got one knocking about?
Ben_Copeland
posted on 2/6/13 at 06:02 PM Reply With Quote
Fiesta ones seem popular with westfields etc
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 2/6/13 at 06:07 PM Reply With Quote
Rover 25 is neat and easy to mount. and quite a popular choice.
Note not the Rover 45 tank which is totally different.
RK
posted on 2/6/13 at 06:24 PM Reply With Quote
Mine is ally and cost about $125 from Moroso. So that wasn't really locost either, but it works, which counts for something.
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 2/6/13 at 06:26 PM Reply With Quote
This one? http://bit.ly/13x1Cl6
Or this one - http://bit.ly/19zIB66 - £6.50 oooosshh !!!
[Edited on 2/6/13 by Barkalarr]
Scuzzle
posted on 2/6/13 at 06:46 PM Reply With Quote
Will a VW one not do the job, they are pretty much the same on everything, Polo's, Golf's, Bora's, Passat etc apart from pipe layout, some have inlets on one side some the other so you should be able to pick one up cheap that will suit your requirements.
NEW Water Expansion Tank for Volkswagen VW Polo Fox SKODA Fabia SEAT Ibiza Mk4
Andybarbet
posted on 2/6/13 at 07:48 PM Reply With Quote
Yep, this is the rover 200 one, I think there are some pictures of the mount I made for mine in my archive.
[Edited on 2/6/13 by Andybarbet]
posted on 2/6/13 at 09:21 PM Reply With Quote
The second ad is just for a pressure cap.
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 2/6/13 at 09:59 PM Reply With Quote
Good spot that man !!! Just as well you did, I nearly bought one.... Doh!!
