givemethebighammer
posted on 11/10/04 at 10:40 PM |
Vacuum take off weber 45's
I've been offered a motorcycle carburettor balancer device (has four gauges and four tubes)
the tubes attach to a vacuum take off somewhere on the carb (not via a "bung" pushed in the from of the carb trumpet). Question is does
the webber DCOE 45 have such a thing (vacuum take off) and if so where is it ?
thanks
Bob C
posted on 11/10/04 at 11:21 PM |
I don't think the webers come with vaccum ports - particularly the port where you'd like to connect the tube from the distributor!
I thought those bike things looked at "manifold" vacuum, so they'd need pipes into the port AFTER the carb, ie on the manifold
rather than the carb.
Might be wrong on all counts of course......
cheers
Bob
gazza285
posted on 12/10/04 at 05:19 AM |
Bike carbs use a balancer as they are of CV design and need to be accurately set up, Webers are numb things and do not require such devices.
