Author: Subject: v8 clutch
lugo35
posted on 12/10/04 at 07:22 PM Reply With Quote
v8 clutch
hiya does anyone know what clutch i need. engine is out of rangerover and gearbox is sd1 5 speed. flywheel is also sd1. the end of input shaft on gearbox is alot smaller than where it should mate do i need spigot bush?????
also will landrover v8 slave cylinder fit and do the job cheers andy
lugo35
posted on 13/10/04 at 07:32 PM Reply With Quote
can no one help?????
Simon
posted on 13/10/04 at 07:39 PM Reply With Quote
Yes, you need a spigot bush - though there may be the remnants of an old bush in end of crank, so check before knocking a new one in. Use SD1 clutch cover and plate. Whilst you are ordering them, suggest you order new clutch cover bolts and (if you haven't already) new flywheel bolts.
Contact someone like Rimmer Bros and ask them about LR slave.
HTH
Simon
[Edited on 13/10/04 by Simon]
lugo35
posted on 13/10/04 at 07:51 PM Reply With Quote
cheers simon helped alot will give rim bros a call.
