Thatcher
| posted on 28/6/13 at 07:13 PM |
Type 9 gearbox
Hi all...
Can I ask you guys a question regarding my type nine gearbox, I have a Duratec bell housing with a hydro clutch actuator, can I or can anyone advise
me on the matter of the gearbox input shaft sleeve is a little too fat for the clutch actuator, so can I cut the sleeve down so that its just the bare
input shaft running through the actuator or should I turn down the sleeve so it can go through the actuator, as I have seen type 9 gearbox's
with bare input shafts but a lot more with sleeves.
Thanks for your advice in advance.
Tony....
Ben_Copeland
| posted on 28/6/13 at 07:29 PM |
That bit???
You're suppose to unbolt it and remove.
Well thats what i did anyway
[Edited on 28/6/13 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
richardm6994
| posted on 28/6/13 at 07:36 PM |
This is what I did...(photos in my rover v8 diary...)
http://www.locostbuilders.co.uk/viewthread.php?tid=177481
big-vee-twin
| posted on 28/6/13 at 08:25 PM |
Yes you cut it off, its only mild steel and quite easy to do Then replace it with a new gasket as there is a little oil return back into the box for
oil that gets through the bearing if you don't oil will leak out.
Also while you are doing that make sure you have a bolt in your bell housing like the one below-it will hold you layshaft in place
[img]
  Layshaft retaining bolt
[/img]
[Edited on 28/6/13 by big-vee-twin]
http://www.triangleltd.com
Thatcher
| posted on 29/6/13 at 04:29 AM |
Thank you guys thats a great help.....
