paulf
posted on 29/9/02 at 12:23 PM |
Sump fitting.
Can anyone tell me if the sump from a 1300 crossflow with an automatic box will fit a 1600 crossflow.I am still looking for a sump for my 1600 engine
and have found an automatic engine and box,as the auto sump is already shorter than a manual i would like to use it but have heard that the crank may
foul due to the longer stroke.
Paul.
theconrodkid
posted on 29/9/02 at 12:59 PM |
i belive the sump is also wider to acomodate the crank stroke,only one way to find out but im sure it will foul
paulf
posted on 29/9/02 at 10:33 PM |
Thanks I have also just found out that the sump wont come off the engine when still in the car, so think I will keep looking or else modify the FWD
sump the engine is presently fitted with.
Paul.
quote: i belive the sump is also wider to acomodate the crank stroke,only one way to find out but im sure it will foul
