Author: Subject: polo rad...im wanting info
maccavvy
posted on 15/7/13 at 07:05 AM Reply With Quote
After thinking about a better rad and fan in my car dude to poor cooling,
I notice the polo rad keeps coming up as its a cheaper option but obviously needs some mods to fit .so heres a few questions
which one do you have?
how did you mount it ?
how is your fan mounted ?
how do you fill it up?
more info and/or pics the better
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
loggyboy
posted on 15/7/13 at 08:09 AM Reply With Quote
Which one do you have? Common one is 1.1 Polo, which is 380w x 320 tall. It has 2x 32mm in/outlets on the left, and i beleive one 8mm bleed hose connection.
http://www.ebay.co.uk/itm/VOLKSWAGEN-POLO-1983-1990-DERBY-SEAT-TERRA-KIT-CAR-RADIATOR-NEW-2-YEAR-WARRANTY-/281080612617
I went for this one which is slightly wider and doesnt have the 8mm bleed hose connection.
http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-1-4-1-6-1991-1998-VENTO-MANUAL-RADIATOR-NEW-2-YEAR-WARRANTY-/290891361243
How did you mount it ? I made up some alloy brackets: http://www.loggyboy.com/images/Raw/Radiator/RadiatorBracketsSide.jpg
How is your fan mounted ? It will be mounted with push through plastic clips:
http://www.ebay.co.uk/itm/UNIVERSAL-ELECTRIC-RADIATOR-FAN-FITTING-KIT-NISSAN-200SX-S13-S14-S14a-S15-SILVIA-/220908855852
How do you fill it up? You need a header tank set up.
Mistral Motorsport
Bluemoon
Surrey fave has some photos in his archive..
renetom
posted on 15/7/13 at 08:10 AM Reply With Quote
Hi
We fitted a polo Rad purchased from Boston radiators £35 + £ 10 P&P, polo 1 ltr 83-90
we made our own aly Z shaped brackets & the polo fan (ebay 95p +P&P)
with steel strips in between the aly brkts.
we cut off the small outlet at the top of rad & araldited a self tapping screw
in the hole, (not required)
The pict of the fan is bent the pict was taken following an accident,
it was just to show how it was fitted.
our layout is for a bike engine but should work equally well on a cec
Waterworks R1 Indy
Waterworks R1 Indy
Rad&fan
Rad&fan
good luck.
René
[Edited on 15/7/13 by renetom]
big-vee-twin
posted on 15/7/13 at 08:26 AM Reply With Quote
I used a seat Leon radiator which is a bit bigger than a polo one and has slightly thicker core.
It fits very snugly under the nose cone mounted at an angle on home made brackets
[img] Sierra Front end
Sierra Front end
[/img]
http://www.triangleltd.com
Sloan85
posted on 15/7/13 at 12:16 PM Reply With Quote
There's 3 entries in my build diary about the radiator and bracket. Polo rad mounted to bracket I made out of 25x4mm steel . 5mm holes on back of rad tapped to take M6 fixings to mount to bracket. Same on the front to mount the fan. I have an expansion tank on the bulkhead where the system is filled from.
Click for build diary
Not finished the car so not sure how well it cools yet!
[Edited on 15/7/13 by Sloan85]
http://mkindygsxr.blogspot.co.uk
maccavvy
posted on 15/7/13 at 05:05 PM Reply With Quote
some good ideas and pics on there. cheers guys.
keep em coming though.
ive got a robin hood 2b so space is a bit fiddly inside the frame but im sure I can knock something up.
Hammy360
posted on 3/12/16 at 02:14 PM Reply With Quote
VOLKSWAGEN POLO 1983-1990/DERBY/SEAT TERRA/KIT CAR RADIATOR NEW-2 YEAR WARRANTY
BRAND NEW RADIATOR VW GOLF MK3 1.4/1.6 PETROL 1991 TO 1998 / VENTO 1992 TO 1997
200 CELL SPORTS CAT STAINLESS STEEL EXHAUST DOWNPIPE FOR RANGE ROVER 4.4 TD V8
Hi mate the link to your image for the brackets goes to a hosting site. I'm trying to put a polo rad in my striker so it'd be great if you have any pics of the brackets
Hammy
