Author: Subject: Might be a silly question!!!
posted on 3/8/13 at 10:55 AM Reply With Quote
Sorry if this is a slack question but do you have to have a cooling fan on the radiator, it's just in the way of my oil cooler??
40inches
posted on 3/8/13 at 11:26 AM Reply With Quote
Simple reply; Yes.
INDY BIRD
posted on 3/8/13 at 11:29 AM Reply With Quote
As above yes but can you not put the fan on the other side of the rad ie not the oil cooler side and changed the fans direction of suck or blow etc ( ooh we misses that sounds rude )
Smoking Frog
posted on 3/8/13 at 11:30 AM Reply With Quote
I would say yes, unless you drive like a granddad in minus temperatures, have a very large rad and never get stuck in traffic. Perhaps a push fan could be fitted in front of the rad or move the oil cooler.
adithorp
posted on 3/8/13 at 11:32 AM Reply With Quote
No you don't... As long as you can guarantee the car will never be stationary with the engine running. So no traffic lights, traffic jams, road works, queuing...
Can't you fit the fan on the other side of the rad?
http://jpsc.org.uk/forum/
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 3/8/13 at 12:41 PM Reply With Quote
How big is your current fan?
I've got a small one knocking about in the garage which came off my R1.
I'm sure a small one is better than nothing at all....
40inches
posted on 3/8/13 at 02:53 PM Reply With Quote
This is true, mine runs at around 80 degrees on the move, even with a 30 degree ambient temp. In traffic the temp climbs to 90degrees and the fan drops it to 85
posted on 3/8/13 at 03:39 PM Reply With Quote
Cheers Indy bird hadn't thought of that.
