kamikaze
posted on 30/9/02 at 06:24 AM |
Engine VS gearbox
Is it possible to fit a escort 1,6 engine from 1988 to a Sierra gear box?
If it is...what year must it be on the gearbox?
rallyslag
posted on 30/9/02 at 06:43 AM |
bolt pattern is the same on most engines/gearboxes from ford
should bolt on easy enough
Old chinese proverb: "If a man speaks in a forest, and no woman hears him, is he still wrong?"
kamikaze
posted on 30/9/02 at 07:04 AM |
OK, thanx...
Then ill buy an engine to day!
Do you know what difference it is between XR2 and XR3 escort´s?
rallyslag
posted on 30/9/02 at 07:21 AM |
depends what year of car it is
some of the xr's used cvh i think
but the later ones used zetecs
kamikaze
posted on 30/9/02 at 07:45 AM |
ITs a escort 1,6 xr3 1988
paulf
posted on 30/9/02 at 08:38 AM |
It will be a CVH engine, the main problem is the engine mounts. I have managed to fit a cvh in my car but had some problems mounting it.Try looking
through the previous messages there has been quite a lot of discussion on this subject.It may be to tall unless you make your chassis sides higher due
to the injection gear.
Paul.
quote: ITs a escort 1,6 xr3 1988
kamikaze
posted on 30/9/02 at 11:45 AM |
I´m not going to use the injectionn i will build my own intake (in titanium )and use MC-carbs..
and Thanks for your help
"Bones heal and chicks dig scars. Pain is temporary,but glory is forever."
