Author: Subject: Lobro driveshaft joint checking
Northy
posted on 17/10/04 at 01:43 PM Reply With Quote
How do you tell if Lobro driveshaft joints are still ok?
Graham
mangogrooveworkshop
posted on 17/10/04 at 04:29 PM Reply With Quote
If they dont give you Knock KnocK jokes when in use. Other than that the clues are rubber boots ok and what condition the grease is in ( Is it contaminated or not) other than that its lucky dip.
Northy
posted on 17/10/04 at 04:34 PM Reply With Quote
Cheers. They're not fitted to the car, they're on the bench!
Should there be any slack in them at all if I hold one end and try to rotate the other?
Graham
Mad Dave
posted on 18/10/04 at 06:48 AM Reply With Quote
Why don't you strip them and check them that way? I did this a couple of weeks ago, its simple really. There are 6 ball bearings, the outer and inner case and a bearing locator thing. Just make sure you mark them up and put them back the right way round if not it will be a locked joint. I drilled a tiny dimple in the outer and inner case so I knew where to align them when rebuilding.
Dave
