y1acw
| posted on 16/8/13 at 10:01 PM |
New Pinto Build
Chassis is 70% complete so I turned my thoughts to the drive train. Finally found a reasonably good low comp transit 2.0 Pinto which I intend
supercharging. I have spent 3 weeks of evenings trying to locate a 1992 Transit wiring diagram so I can assemble an ignition system but have failed
miserably. Can anyone help with a wiring diagram or send me a link ? the dizy is Bosche contact less 3 wire , carb is Webber with stepper motor and
auto choke. Please help me out of my misery.
Alistair
Dusty
| posted on 16/8/13 at 10:35 PM |
I would be guessing that the transit used the bosch inductive unit, same as in the P100 sierra and same wiring diagram. In reality you can fit
anything from a pinto sierra as long as you get the complete kit or even an old points dizzy from a cortina or capri that had a pinto. Aftermarket
alternative like accuspark or magnetronic. Megajolt?
Three wire dizzy and inductive unit below. The earth wire in that big plug is not used in sierra.
[img]
  Inductive + Bosch 2 wire Dizzy
[/img]
Mikef
| posted on 17/8/13 at 11:50 AM |
Have a look at Nodiz,I have found it works a dream on my Pinto and far better than a distributor system. I found them very helpful to deal with.
MF
y1acw
| posted on 17/8/13 at 08:13 PM |
Gents thanks very much for your advice. Just to make matters more difficult my Dizy has no vacuum advance .Any idea why my profile still shows
"unverified" even though I made a donation ?
Alistair
