AndyW
| posted on 24/8/13 at 03:16 PM |
type 9 rear oil seal cont...
Should I be able to see the oil seal in the output shaft of a type 9 gearbox?
Pointed a torch up there today and could not see past the splined bit to see old/failed oil seal. Bad picture, I know but here is what I could
see.....
[Edited on 26/8/13 by AndyW]
big-vee-twin
| posted on 24/8/13 at 03:38 PM |
It sits right at the end I can see it in the photo its the rubber ring pushedninto the end the shaft passes through it.
http://www.triangleltd.com
Dingz
| posted on 24/8/13 at 06:19 PM |
Andy make sure that the end of the propshaft (the bit that runs against the seal) is nice and polished no burrs or marks on it otherwise it will
damage the new seal and you will be back to square 1!
went on and on.
AndyW
| posted on 24/8/13 at 08:25 PM |
You say you can se it in the photo, I could not see anything!! Any hints on getting the old knackered one out??
Dusty
| posted on 24/8/13 at 09:40 PM |
It's the bit lying just inside the tail extension of the gearbox, roughly crossed by the red zigzag. Might be the angle of the pic but it looks
to me as if the seal is not in square, seeming deeper in at 4 o'clock ish position. Might just be the pic. There is space between the output
shaft and the seal to get a nice hooky slide hammer in or crudely lever it out with a screwdriver.
[img]
[/img]
[Edited on 24/8/13 by Dusty]
AndyW
| posted on 26/8/13 at 08:27 AM |
I thought that might be it. I will have a look today and see if it is in square, and will try and remove it some how. Now my g/box is empty of all oil
should not be too hard. Need to get this done by Wednesday latest no pressure as usual!!!
