Author: Subject: V-belts, how tight are they supposed to be?
Irony
posted on 6/9/13 at 09:58 AM Reply With Quote
Just put my vbelts on my Rover V8 for the first time. Quite happy as I go the correct lengths first time.
How tight are they supposed to be? I pulled on the tensioners with all my strength and did them up and they seem okay. Is it just a case of looking for any slippage when I finally get it running? It is for the water pump and alternator.
loggyboy
posted on 6/9/13 at 10:00 AM Reply With Quote
ive always worked to 1cm of deflection on the longest run between pullets.
Not very scientific, but never had any issues.
Mistral Motorsport
posted on 6/9/13 at 10:33 AM Reply With Quote
The belt must not be too tight --- you need a little deflection to avoid over loading the bearings.
Rover V8s with single Vee alternator belts are infamous for alternator belt slippage immediately after a cold start you have to live with it.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 6/9/13 at 01:34 PM Reply With Quote
I was taught that 1/2" per foot run was right for any V belt......
Slimy38
posted on 6/9/13 at 02:05 PM Reply With Quote
I've also noticed belts stretch slightly when first run, I've often found myself getting another turn or two out of the adjuster after the first 200 miles or so.
Irony
posted on 6/9/13 at 02:54 PM Reply With Quote
Thanks a lot!
