myke pocock
posted on 7/9/13 at 08:39 PM |
Type 9 to x flow
Predictably things are not going to plan!!! I am fitting a type 9 box to my x flow engine and have discovered that the input shaft on the 4 speed box
I have taken out is smaller than the type 9, (22mm OD for the 4 speed and 27.15mm for the Type 9) Where do I source a front yolk and splined tube unit
to fit to my existing prop shaft?
[Edited on 7/9/13 by myke pocock]
sjmatthews
posted on 7/9/13 at 09:09 PM |
You'll have to change the clutch
I'll be in the garage dear!
myke pocock
posted on 7/9/13 at 09:57 PM |
Yes, I have the correct friction plate, its the input shaft on the Type 9 that differs in size from the 4 speed prop.
wicket
posted on 7/9/13 at 10:28 PM |
Do you mean the output shaft of the gearbox, if so get your prop shaft modified to suit the type 9 output
black fingernail
posted on 8/9/13 at 08:19 AM |
You'll need to fit a propshaft end from a ford that uses that size gearbox shaft and has a hardy spicer type joint fitted. a lot of the sierras
and transits had a rubber do-nut fitted, these are no good as they don't fit in the transmission tunnel.
capri's, a lot of the 'v' engined fords, early sierras, etc. are a good source.
slingshot2000
posted on 8/9/13 at 09:21 AM |
quote: Originally posted by myke pocock
I discovered that the input shaft on the 4 speed box I have taken out is smaller than the type 9, (22mm OD for the 4 speed and 27.15mm for the Type 9)
You need a bearing that fits inside the end of the crossflow crankshaft, I cannot remember the correct name, but it is (or certainly was), and off
the shelf Ford part. Maybe someone like Burtons could help you out with this?
Regards
Jon
slingshot2000
posted on 8/9/13 at 09:23 AM |
Regards
Jon
Whoops, just read this again, and It seems I was heading in the wrong direction, you need the type 9 input shaft turning down to 22mm OD to enable it
to fit into your crank.
Regards
Jon
myke pocock
posted on 8/9/13 at 09:28 AM |
Think I am confusing people. The problem is at the REAR of the gearbox where the prop shaft fits to it. I need a new yolk with the spline that fits my
gearbox and I think one of the replies has identified that so many thanks.
posted on 8/9/13 at 10:25 AM |
Bailey Morris should be able to help you, all you need is a Sierra propshaft with the correct sliding joint. The Sierra has a rubber doughnut behind
the box but my prop from BM came with a sliding joint and UJ much the same as the one next to the diff.
