unijacko67
posted on 17/9/13 at 08:25 PM |
Nearly standard s2000 on the rolling road
Just had my s2000/Kitten on the scales with full fuel tank and total weight is 760kg with full cage and door bars, then on the rollers and has a very
strong 195bhp at the wheels. The main reason for the rolling road test was to check the exhaust gasses right through the rev range and make sure its
not got any lean spots as I have fitted a home made exhaust and altered the intake also removing the cold air pump. All is well with it running very
slightly rich at full throttle which is fine.
http://www.kittenkitcar.co.uk
Nickp
posted on 17/9/13 at 08:54 PM |
Good work, look forward to seeing it at Blyton (and maybe having a ride?)
unijacko67
posted on 17/9/13 at 09:00 PM |
If all goes well, yeah no problem.
