scutter
posted on 26/10/13 at 09:42 PM |
Alfa balance pipe
I've fitted a 3.0L Alfa 12v to my Haynes Roadster and am currently look at the exhausts.
The question I have is what diameter does the balance pipe need to be? I'm planning on using a 38mm internal primaries and 58mm exhaust
system.
Knowing the size will help with routing around the sump to linking the systems.
Regards Dan.
owelly
posted on 27/10/13 at 07:58 AM |
I used a 45mm dia link pipe and it made the exhausts a bit quieter but seemed to have no effect on power.
http://www.ppcmag.co.uk
clairetoo
posted on 27/10/13 at 08:22 AM |
I use 25mm on my Mazda V6 conversions - the stock Mx6 exhaust has a very small link pipe , maybe 20mm , but its only about 25mm long !
Its cuz I is blond , innit
Claire xx
Will weld for food......
scutter
posted on 27/10/13 at 10:20 PM |
Ok, changing tack completely, what purpose do they serve? Is it needed?
Regards Dan.
mark chandler
posted on 27/10/13 at 10:30 PM |
Serves no purpose on a 6 cylinder except to improve the sound, without when you stand to one side of the car you hear 3 cylinders instead of 6.
scutter
posted on 27/10/13 at 10:46 PM |
Hmmm, the Alfa was partially chosen for it's noise.
Best I find a way to preserve it then.
Regards Dan.
