Dave Bailey
posted on 3/11/13 at 06:09 PM |
Running issues...
Well managed to get out for an hour today -. I have noticed a couple of things I need to address now that I have covered 100 miles.... Weather is
not that cold but struggling to get above 65 -70 degrees... Only have the small micra ally rad so need to think about restricting cooling... Problem
is left idIng the temp soon goes up at which point I need the fan to draw for cooling... Next thing to look at s to understand if I am loosing a
bit of fuel pressure... Target iOS 3 bar but I have a pressure transducer reading about 2.8 but this drops to about 2.65 - 2.7 whilst driving... Nit
sure if this is normal....
Dave B
posted on 3/11/13 at 07:45 PM |
You need to fit a thermostat in the cooling system, also if you have a thermostat you need a by--pass connection.
Ben_Copeland
posted on 3/11/13 at 07:46 PM |
Sounds like you might have a cool running thermostat or worse no thermostat?
Fuel pressure could just be dropping slightly because while your driving it's using more!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Dave Bailey
posted on 3/11/13 at 07:55 PM |
I do have a thermostat but possibly the bypass is a bit big..... I will have another check.... Idling the temp gets to 85 no problem and the fan
cuts in.... What sort of temp should I be aiming for?
I will have a check....
Thanks guys....
Dave B
posted on 3/11/13 at 08:11 PM |
Thanks guys....
Dave B [/quthat.
The size of by-pass won't effect that.
Normal thermostat starts to open temperature would typically be 88c. Fan cut in temperature should be about 96c and cut off temperature about 93c.
Dave Bailey
posted on 3/11/13 at 08:37 PM |
Thanks guys.... I think I will do a sensor and stat check next weekend...
Dave B
