Nitrogeno25
posted on 24/11/13 at 08:08 PM |
What happened with my type 9?
After a short blast I found a big oil leak from the gearbox. Today I finally take it out and found this:
This is a standard type 9, and it doesn't look good It seems that the case is broken and metal debris are around this area.
The box was rebuild 2K miles ago and was working fine even when I stop after dissasembly.
What do you think?
Many thanks.
madteg
posted on 24/11/13 at 08:42 PM |
Looks like bearing has seized and spun the outer race casing casing to brake.
big-vee-twin
posted on 24/11/13 at 09:06 PM |
The type 9 layshaft does come through the casing by design.
The shaft is then held in place by the flat face on the back of the bell housing.
The Duratec bell tends to have a hollow or pocket in the back, so a bolt is put in place like the pic below to stop the shaft moving forward.
Do you have a bolt in place?
[img]
![](/galpreviews/Duratec bell housing mod.jpg) ![Layshaft retaining bolt](/gallery/Duratec bell housing mod.jpg) Layshaft retaining bolt
[/img]
[Edited on 24/11/13 by big-vee-twin]
http://www.triangleltd.com
Nitrogeno25
posted on 24/11/13 at 09:31 PM |
[img]
[/img]
Yes I made a spacer out of aluminium (threaded and bolted to the bellhousing).
Could this be a result of improper assembly?
[Edited on 25/11/13 by Nitrogeno25]
Nitrogeno25
posted on 24/11/13 at 09:37 PM |
I undestand the layshaft come through the casing, but it seems the bearing also come in mine (it was not like that obviously.)
Could it be the bearing that support the gear cluster was placed incorrectly causing it to seized and start turning causing the casing to brake like
that (almost like the bearing has machined the casing from the inside)?
I'm preparing the wallet now
[Edited on 24/11/13 by Nitrogeno25]
Dusty
posted on 25/11/13 at 01:09 AM |
Some type 9 boxes were made as original with a heavier duty front layshaft bearing. (i.e. V6 boxes) but these had a three bolt plate holding the
bearing and a machined slot in the back of the bellhousing to accommodate the plate. Not one of those I think. BGH certainly do an uprated front
layshaft bearing, fitted flush with the front face of the box but no plate the hole for it having been machined straight through from the front.
Intended to be used with the standard bellhousing which closes it off and holds it in place. I suspect it is one of these although not necessarily
BGH, Quaife and others did them.
If it's been used with a spacer or bellhousing with the machined slot like the duratec spacer shown the bearing may have been unsupported from
the front and moved before seizing.
Nitrogeno25
posted on 25/11/13 at 01:55 AM |
I'm almost sure I could only see the layshaft through the case, now the hole seems bigger and the bearing is exposed. I found debris when I
unbolted the bellhousing so something is really wrong there.
Can these be fixable (without a new gearbox)?
Paul Turner
posted on 25/11/13 at 02:25 PM |
That looks like no other type 9 I have ever seen. If it was built like that it was a bodge to begin with. Cannot see how the bearing could damage the
case to the extent visible. Honestly you have a serious issue. The case is almost certainly knackered unless it could be modified for a bigger bearing
compatible with the HD front spiggot.
Nitrogeno25
posted on 25/11/13 at 03:00 PM |
No, it wasn't build like that, I'm sure because I fitted this gearbox less than a year ago. Interesting that the box was working fine, no
noises, perfect gearchanges. I removed it because of the big leak between the box and bellhousing.
Thanks!
Paul Turner
posted on 25/11/13 at 03:35 PM |
I would suggest that the minimum required would be a replacement casing, layshaft, bearings, gaskets etc and a good deal of praying that the laygear
assembly, gears etc are all OK.
Nitrogeno25
posted on 25/11/13 at 03:47 PM |
Yes, or I'm thinking of a new box from SPC o BGH... not that easy being from the other side of the world, but I'll try.
