Author: Subject: Clutch noise on depresses pedal
richardh
posted on 2/12/13 at 09:42 AM Reply With Quote
When i press the clutch pedal down, there is a strange noise (rubbing sound possibly)
Once pedal is back up the noise stops.
No noise when driving.
There's some "rusty or muddy" looking water coming out of somewhere under the engine. (this vitara spent the last few months playing in the mud)
I've jetwashed the life out the underside to clean it up but wondered if this was maybe either a gasket split or a clutch bearing.
Time for a change!
Wadders
posted on 2/12/13 at 09:58 AM Reply With Quote
Sounds like your release bearing is knackered.
snapper
posted on 2/12/13 at 10:59 AM Reply With Quote
S4it in the release bearing
I eat to survive
I drink to forget
chrism
posted on 2/12/13 at 09:49 PM Reply With Quote
Release bearing as others have said, I believe its quite a common problem on vitaras and samurais.
A little hard work never killed anyone, but why take the risk!
elizaharry
posted on 30/12/13 at 05:51 AM Reply With Quote
Clutch free play needs to be adjusted, which would be done by replacing the rubber stopper.
