alan87
| posted on 16/12/13 at 03:05 PM |
Cable clutch to hydraulic clutch...best way to go about...
Afternoon,
I am in the process of converting my fury from cable to hydraulic clutch. As you can see below the current spacing for all the master cylinders will
be wrong, and I need a new mounting point for the clutch ms. I'm thinking the simplest way will be just to cut out the bottom 3rd of bulkhead
and weld in a fresh section in with master cylinder holes per cut.
Has anybody done this or similar that can verify?
Also does anybody have a cad template knocking around with master cylinder spacing that I could adapt?
[/URL]
samjc
| posted on 16/12/13 at 03:50 PM |
Mine was semi similar as when i bought the car the pedals were far to close for my size 12s so i respaced them and cut out a large rectangle where the
cylinders mounted to fit a new plate (bolted in for ease of maintenance) with my own setup and ment if i needed to change it again i dont need to cut
and weld ect. I also used the old pedals but made a new base to space the pedals further apart.
samjc
| posted on 16/12/13 at 03:53 PM |
With your setup wouldnt the easiest option be to space the clutch cylinder back from the others and widen the old cable hole allowing the push rod
from the cylinder plenty of room. Just means a londer cylinder rod and some for of spacers and long bolts if you can secure it well enough like that.
alan87
| posted on 17/12/13 at 05:41 PM |
Sam I hadn't considered spacing the cylinder back. I'll have a look tomorrow, but I don't think there will be enough space. I like
the idea of a removable panel though. I may cut out a rectangle weld sa box section frame inside and then attach the panel to that. Would add some
much needed rigidity aswell.
samjc
| posted on 17/12/13 at 06:01 PM |
Ill try to find a picture of mine and pop it in my archive tonight for you as its much easier with a removable pannel. Altho above the pedals im
making another removable pannel to easly adjust the bias bar ect rather than climbing down my foot well.
alan87
| posted on 29/12/13 at 11:10 PM |
Hi Sam,
I've just checked your archive..are you able to upload those pictures?
samjc
| posted on 30/12/13 at 12:22 AM |
Sorry slipped my mild uploading them now.
samjc
| posted on 30/12/13 at 12:27 AM |
samjc
| posted on 30/12/13 at 12:29 AM |
  inside pedals
samjc
| posted on 30/12/13 at 12:30 AM |
By the way alan87 who made your pedals ?
alan87
| posted on 30/12/13 at 10:48 AM |
Sam thanks for those. The pedals are from fury sports cars.
Out of interest how did you cut/ measure the holes for the master cylinders on that plate?
samjc
| posted on 30/12/13 at 03:49 PM |
No priblem sorry for the delay,
First cut the plate and taped the chassie holes ready to remount. I unded a hole saw but cannot remember the size i may be able to check for you if
needs be and as for spacing i was fortunate to already have an old setup to work off as mine just needed the master cylinders moving from insode the
tunnel to outside. But im sure people on here can offer measurements. I can check mine if needs be
Andy S
| posted on 30/12/13 at 04:34 PM |
Yours also looks like an early chassis - Mine is a 2004 chassis and it does not have the added brace - the bulkhead does flex - alarmingly so worth
redressing when you do the changes
This is from Rob Collingridge's site showing the later braced chassis
alan87
| posted on 1/1/14 at 08:23 PM |
Thanks Andy I had seen the bracing before and had intended doing something as part of the New pedals.
