pekwah1
posted on 28/12/13 at 10:26 PM |
Fitting a fuel pump to the tank
Hi Guys,
So i've got a bike pump that i want to fit to my tank.
This is going to require cutting a bit hole in the bottom of the tank and then drilling the smaller holes for the bolts.
Only thing is that the tank isn't exactly thick metal, maybe 1-2mm, this doesn't seem thick enough to be tapping holes for the pump to
bolt to.
Any suggestions?
Only idea at the moment is get a much thicker plate welded onto the bottom of the tank and then tapping this?
rodgling
posted on 28/12/13 at 10:47 PM |
I tapped my tank (probably 1 or 2mm aluminium) - it's not very satisfactory but it did do the job, so it might be OK (you'll need a bit of
thread lock to make sure it seals). But yeah, welding something on would be better.
scimjim
posted on 28/12/13 at 10:53 PM |
or make up a ring holding captive nuts to go inside the tank?
pekwah1
posted on 28/12/13 at 10:58 PM |
i thought of that but how would i get the ring inside the tank without cutting an even bigger hole?
NigeEss
posted on 28/12/13 at 11:06 PM |
A tube with a wide flange, sort of top hat shaped. Sealant and closed end rivets or self tappers.
pekwah1
posted on 28/12/13 at 11:08 PM |
Nige, i have no idea what you're on about!!!!
NigeEss
posted on 28/12/13 at 11:17 PM |
Ah, I've re-read your first post, you're not after an outlet pipe as I first thought so ignore my comment
As for a tapped ring, make it in two halves ??
Dave Bailey
posted on 28/12/13 at 11:23 PM |
What about using rivnuts? Memfast do a great tool and various size rivnuts...
Dave B
scimjim
posted on 28/12/13 at 11:29 PM |
I've just made one but it's for an oval hole - presume yours is perfectly circular then? if so, make it in two halves as suggested.
pekwah1
posted on 28/12/13 at 11:30 PM |
problem with rivnuts is they dont sit flush so i won't get a seal on the pump
Dave Bailey
posted on 28/12/13 at 11:32 PM |
They do some very low profile heads so if there is a gasket I would think they would be ok... But point taken....
Dave B
mark chandler
posted on 28/12/13 at 11:53 PM |
Horse shoe shape then you can feed in, couple of blobs of sealant to hold in place while you bolt in the pump, job done.
pekwah1
posted on 28/12/13 at 11:56 PM |
cheers guys, think i'll go with the horseshoe idea
posted on 29/12/13 at 12:04 AM |
What kind of pump is it? I just strapped my bike pump to a chassis rail and gravity fed it from the tank..
PAUL FISHER
posted on 29/12/13 at 01:57 AM |
I had Martin Keenan, at MK engineering put a injected Fireblade pump into my tank a few years ago, worked very well, it even had a small sump built
into it
[img]
![](/galpreviews/a523446-specr 125 (Small).jpg) ![Rescued attachment specr 125 (Small).jpg](/gallery/a523446-specr 125 (Small).jpg) Rescued attachment specr 125 (Small).jpg
[/img]
