TimC
posted on 11/1/14 at 07:56 PM |
Is a 10mm feed to the coolant system too small?
On a BEC, will a 10mm ID feed from the header tank to the coolant system be too small? The bike's is actually very small but most cars'
are much bigger.
chrism
posted on 11/1/14 at 08:21 PM |
If its just the header then I would say it would be ok as doesnt need much flow.
A little hard work never killed anyone, but why take the risk!
mark chandler
posted on 11/1/14 at 08:22 PM |
Header tank on the bike is not a full flow through as such, provided the radiator is plumbed with big pipes then 10mm is fine for the header as
it's really just for expansion and for any bubbles to blow into.
Wheels244
posted on 11/1/14 at 08:25 PM |
Fairly certain the bore on mine was 10mm Tim
Build Blog: http://wheels244.wordpress.com/
Wheels244
posted on 11/1/14 at 08:26 PM |
And I just pressed the wrong vote button - Doh !
adithorp
posted on 11/1/14 at 09:49 PM |
Won't be a problem.
http://jpsc.org.uk/forum/
TimC
posted on 11/1/14 at 09:55 PM |
Thanks all.
