Author: Subject: twin engined mini help
fs1eman
posted on 28/1/14 at 08:21 PM Reply With Quote
i have a twin engined mini with 2 r1 engines in can't get carb setting right, i have no room for air filters so have jetted it up on the mains but still don't like it any ideas thanks newly
Dangerstevie
posted on 30/1/14 at 02:36 PM Reply With Quote
The CV carbs and no airboxes or filters are a nightmare, ive had major problems with my fireblade streetfighter on CV carbs with no airbox. Ive ended up modifying a standard airbox and ive managed to get it perfect now but it was a bitch without the airbox.
With a factory pro filter kit the blades have to run 160 mains, with no filters i think you will have to run much bigger.
fs1eman
posted on 30/1/14 at 03:22 PM Reply With Quote
thanks for the info have gone up to 220 mains , still trying
dave_424
posted on 30/1/14 at 04:27 PM Reply With Quote
What were the standard main jet sizes? going to an open filter should only need about a 10-15 increase in jet size.
Dangerstevie
posted on 30/1/14 at 05:29 PM Reply With Quote
Std mains on my blade are 120 but with a factory pro kit you need 160mains and without airbox more like 180-200. Are your carbs in the r1 balanced?
davidimurray
posted on 30/1/14 at 06:17 PM Reply With Quote
When you say can't get it right - where is the issue low, mid or wide open throttle?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
