Author: Subject: Quaife reverse box
strikerbird
posted on 11/2/14 at 10:47 AM Reply With Quote
Quaife reverse box
I've had a quaife reverse box delivered today and I'm unsure which way round to put it in the car.
There is a tag on one of the flanges saying longest prop this end, but by putting it that way my reverse lever will be back to front!
Are the bearings stronger in one end or something?
Depending on the install the long prop could be front or back
Bit confused!
designer
posted on 11/2/14 at 10:52 AM Reply With Quote
Why don't you just ask Quaife? They supplied it!
Wheels244
posted on 11/2/14 at 10:55 AM Reply With Quote
When I put mine in, I put it with reverse light switch on the left hand side as you're sat in the drivers seat looking forward.
HTHs
Rob
Build Blog: http://wheels244.wordpress.com/
corrado vr6
posted on 11/2/14 at 06:05 PM Reply With Quote
Same as above
So when I want reverse I have to push the lever forward and for forwards or (reverse box dis-engaged) the lever is up straight
http://r1indy7.wordpress.com/
